Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Use the right number of O rings (1) and put it back together.. Make sure that they are Viton.. They are standard - 013 sized O rings. If you want use a very little bit of ultra black at the crack..
