Cam Plate and Oil Pump Confusion
Hello ,
I am looking at Buying a 2000 Dyna Wide Glide with 18 k miles, bone stock w/Carburetor .
I was looking at cam Plates and oil pumps, wanting to use hydraulic adjusters and more oil pressure.
I cannot not find one from what I understand , there is a difference in 99-01 T/C?
I saw where is would work if one of the original sprockets where used because of the Morelli timing marks?
Any advice3 on what I can Run??
Thank You
Thank You
Feuling makes the kit for your year and the cam gear has the timing ridge to work with the sensor.
This one is for use with your OEM cams: https://www.feulingparts.com/sku/7089
JTM65 (05-02-2024)
Received 8,768 Likes
Camchèst and oil pumps
I have a 2000 FXDWG WideGlide carbureated.
You must not be looking very hard for your parts. There are a few options and retailers where you can find what you are looking for. One of the sponsor vendors on this website (on the right side of this screen) is Fuel Moto. You can call them with your questions and order directly from them. Otherwise google Fueling - S&S - or the Harley-Davidson website for parts.
https://www.harley-davidson.com/us/e...-service-parts
98hotrodfatboy
Twin Cam Motors
02-22-2023 03:10 PM
