HELP! will 2004 flywheel fit my 99
Old Sep 25, 2024 | 05:48 PM
harleyrider06010's Avatar
harleyrider06010
Default HELP! will 2004 flywheel fit my 99
Hi, i have a 1999 flhtc and the cranks done. Will a flywheel from a 04 fit my bike? do I need any major machining? The one I can get has about 17000 miles on it! But if it dont fit its useless to me
TIA
Old Sep 25, 2024 | 07:52 PM
GalvTexGuy's Avatar
GalvTexGuy
Old Sep 25, 2024 | 08:03 PM
Ohio HD's Avatar
Ohio HD
TIA
A couple of things. You didn't mention what the 2004 crank is from, what model. If the 2004 is an 'A' motor, then the crank will fit in your 1999 FLHTC. That being said, your 1999 motor uses a Timken bearing. The 2004 uses a straight roller bearing. You have to prepare the 2004 crank, you need to pull the left side bearing race off the sprocket shaft.
You also need to know how to setup the Timken bearing in the 1999. A factory service manual should be consulted before even trying to pull the 1999 crank out.
Old Sep 25, 2024 | 08:26 PM
Harley_ish's Avatar
Harley_ish
To the OP ...
Originally Posted by Ohio HD
... the 2004 is an 'A' motor, then the crank will fit in your 1999 FLHTC ...
'A' = all big twin except Softail ... (if you didn't know already)
Old Sep 26, 2024 | 11:26 AM
harleyrider06010
Thanks Yes its an A motor flhtc
grizzlygar
Feb 26, 2022 07:47 PM
vdude
May 21, 2019 04:54 PM
KIDD_ADMC
Feb 7, 2014 11:01 PM
tdgarry
Sep 7, 2009 01:47 AM
97fxdl
Mar 5, 2007 01:20 AM
