backfire on letoff
Old Mar 21, 2011 | 04:45 PM
harleydwg555's Avatar
harleydwg555
Default backfire on letoff
2000 fxdwg k&n vance and hines pipes but everything else stock. performance is good, idles good, but backfires thru exhaust when throttle is reduced..
too much fuel? smaller jet? don't ever let off?
thanx in advance
Old Mar 21, 2011 | 07:30 PM
harleydwg555
Default also
thanx in advance
Plugs appear to be running lean? as well so?
Old Mar 21, 2011 | 07:35 PM
Thatzmister2u's Avatar
Thatzmister2u
Did you install slip ons? Did you reuse the clamps or put new ones on? Might be exhaust leak.
Old Mar 21, 2011 | 08:30 PM
harleydwg555
no they are 1 piece nice pipes..it is carbed so will take it offf tommorrow and check jets
Old Mar 22, 2011 | 06:05 AM
Mike T's Avatar
Mike T
Popping on deceleration, it is running lean.
Old Mar 22, 2011 | 08:57 PM
harleydwg555
thanx mike i think your right!
Old Oct 15, 2011 | 09:45 PM
BrianG's Avatar
BrianG
Check the pilot jet and go one size larger. Mine was a 45 - went to 49. Set the idle jet to 2.5 turns. Tune from that point.
Also put a shim under the needle in the throttle slide, about 0.050". (one hardware-store washer).
Whodattom
May 9, 2014 08:08 AM
blackflame
Jun 25, 2013 09:57 PM
K9Tamer
Aug 7, 2012 04:40 AM
Timax52
Exhaust System Topics
Mar 18, 2012 05:55 PM
Alexander321
Oct 16, 2011 07:05 PM
