tappet adjustment
Old 04-21-2017, 05:06 PM
row jimmie's Avatar
row jimmie
row jimmie is offline
Default tappet adjustment
Near as I can tell my pushrod are 24 threads per inch. I came up with 2 and a half turns adjustment. Any thoughts?
Old 04-21-2017, 05:09 PM
row jimmie's Avatar
row jimmie
1996 80 inch
Old 04-21-2017, 06:41 PM
glidein wide's Avatar
glidein wide
glidein wide is offline
0.140" from zero lash is considered the goal.
Old 04-22-2017, 06:38 AM
row jimmie's Avatar
row jimmie
Thanks, I thought the goal .100, u like them longer because. I've been called a troll so I hope I don't offend by asking.
Old 04-22-2017, 07:13 AM
daven9113's Avatar
daven9113
daven9113 is offline
If you are not sure what brand PRs you have, then make sure you count how many threads in one inch you have to be safe. Adjusting them longer than .100 will reduce valve train noise.
Old 04-22-2017, 07:29 AM
glidein wide
The 0.140" came from the professionals..here are my notes..(s&s adjustable rods, 32 TPI). I've tried these settings , 0.1352" , 0.1456" , 0.1612" , 0.1404".....ev27 cam still makes for a noisy top end at all of these settings, I blame it on the crap screaming eagle lifters I bought.
Old 04-22-2017, 08:21 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,817 Likes on 3,319 Posts
Don't even know who makes them for HD. That's the scary part....
Yea 24 Tpi=20 flats=.138"
Old 04-23-2017, 08:20 AM
Uncle G.'s Avatar
Uncle G.
Uncle G. is online now
Received 3,704 Likes on 1,989 Posts
The EV27 cam has very fast opening and closing ramps to get a lot of lift and relatively short duration. No matter what you do it's going to be a noisy cam. At least in my experience.
glidein wide (04-23-2017)
Old 04-23-2017, 08:34 AM
1997bagger's Avatar
1997bagger
1997bagger is offline
Received 1,688 Likes on 852 Posts
[/B]
They are Jim's, HD started to try to unload them because they were overpriced and sat on the shelves.
.100 is the factory lifter setting, this depth will work for 80% of aftermarket cams. Woods, Redshift, EV27 has "square" lobes that shocks the Evo push rod system. A Evo cylinder and head can grow .030 with heat expansion, a sqaure lobe cam can expose the changed lifter when it goes to the looser side depth by clatter. The deeper plunger setting in the lifter covers the expansion plus taming the noise created by the race profile cam
JustDave71
Exhaust System Topics
06-28-2011 11:50 AM
tvr
06-14-2011 08:37 PM
gunnerglide
05-28-2011 06:09 PM
Gliden
Engine Mechanical Topics
04-19-2010 01:00 PM
95CHUCK
05-02-2008 11:40 PM
Quick Reply: tappet adjustment
