94 road king... Any stock style exhaust that let you pull the clutch cable?
Hi Guys,
I've got a 94 road king that I put a lot of miles on, and ended up throwing the stock head pipes back on because the duals I had on kept cracking.
My stock pipes are starting to rust and get thin behind the rear head, so I'm looking for another set of take offs. I gather that from 08 backward fit just fine, as I've already got the flanges cut off mine to take the late model style slip on muffler clamps.
I'm curious, if any of the years that will bolt onto a 1994 don't require pulling the exhaust to remove the transmission right side cover to get at the cable/throw out bearing.
That just seemed like a stupid design on harleys part. Not that it takes an afternoon to pull the exhaust, but just that you damn near have to over one or two allen bolts.
Cheers,
Zach
Cheers,
Zach
Received 5,388 Likes
You can either do the ex removal, or cut an Allen key short to have clearance. BTW- Harley STILL mounts the rear axle in the wrong direction. You have to remove the ex end can to pull the axle...(at least on Dyna's).
One of the first "mods" to do is to fix this.
EDIT-
While you have the clutch actuator apart, you might install a Burley EZ Boy clutch device. Best 20 bucks you'll spend on ur bike. No, I don't get anything from them. Reduces clutch pull 40%.
Also, I've got a stock full system from my 1995 Dyna superglide. Probably rusty as heck. Don't know if they'll fit your RK. Come to think of it, probably won't fit. Oh well.
EDIT-
Hi Zach, as you already comment, any stock system up to 2008 will fit your bike. Some '07 and all '08 sets have O2 ports, so will need blanks to fill them. I have an '08 SuperTrapp on my 1990 Glide below.
As for access to the cable/throw out bearing, I hardly ever need that! An alternative to the Burly is a new clutch cable. I have a H-D Diamondback, but I gather Barnett make a similar one. It's so remarkably smooth and light I took off my Clutchlite (similar to a Burly). On some bikes, including mine, they steal some of the free play in the system and make adjustment critical.
Hi Guys,
Cheers,
Zach
Cheers,
Zach
Appreciate it guys! From studying the microfiche and pictures online, it looks like they didn't change the design enough to between 94 and 08 to gain that access.
I like the idea of a 2:1 for the scavenging. I haven't found one that is half way quiet. I tow a camper trailer, and had a set of super-trapp look alike slip on's when I bought her. Damn near box your ears out with the sound bouncing back off the trailer going up the mountains. 3rd gear and 4k rpm makes for a screamer.
It looks like the fullsac dual conversion kit would replace the rusted pipe I've got and gain access at the expense of some low end torque. https://fullsac.com/product/true-dua...8-flh-touring/
Anyone tried one of those? The right side pipe slips into the existing front cylinder head pipe and connects to the right side muffler, so it'd be down-right easy to get out of the way. We do a lot of road tripping, so when ever I make a change to the bike I try to move in a direction that takes fewer tools and gives easier access if I do need to open something up.
Cheers,
Zach
Cheers,
Zach
I have tried a Fullsac TD kit, some years ago. It was OK, but TDs typically give a torque dip right where most of us ride (did on my bike) which the Supermeg cured and then some.
Comfortably Numb
05-03-2021 12:45 AM
