clutch cable replacement
Old Jun 2, 2013 | 10:35 PM
berndog's Avatar
berndog
Default clutch cable replacement
Snapped clutch cable today,so i'm wondering ,is it possible to replace without removing exhaust entirely?
Old Jun 2, 2013 | 10:44 PM
davessworks's Avatar
davessworks
Well, you have to get to the clutch release cover and remove it. If you can do that without removing the exhaust then go for it.
Old Jun 2, 2013 | 10:45 PM
Def Mute's Avatar
Def Mute
Maybe...
Depending on the bike, and the exhaust.
Usually, with stock header pipe? No.
Old Jun 2, 2013 | 10:53 PM
kyote's Avatar
kyote
if you can get at the allen head bolts then yes.. I have changed mine twice without taking the exhaust off..
Old Jun 3, 2013 | 12:34 AM
berndog's Avatar
berndog
2001 rk classic
Old Jun 3, 2013 | 12:45 AM
DAVENRINO's Avatar
DAVENRINO
You might try a ball socket hex. You may still have to remove the heat shield and/or loosen the pipe from the head..
Old Jun 3, 2013 | 01:22 AM
davessworks
Sure but eventually you have to put it all back together again and torque it back down correctly. Just not worth mucking around. How long does it take to pull the exhaust and o the job right anyway?
davessworks
Sure but eventually you have to put it all back together again and torque it back down correctly. Just not worth mucking around. How long does it take to pull the exhaust and do the job right anyway?
fenwick
Jun 23, 2014 05:17 PM
ZenGlide
Mar 7, 2014 07:56 PM
marvo75
May 6, 2013 08:30 AM
aggro_jo
Dec 14, 2008 08:07 PM
Lone Watie
Feb 19, 2008 07:33 PM
