clutch cable
Old Jun 22, 2014 | 09:58 PM
fenwick's Avatar
fenwick
Default clutch cable
are there any tricks to replace clutch cable on 08 EG with out taking exhaust off
Old Jun 22, 2014 | 10:14 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Loosen off the exhaust flange nuts and all the brackets and maybe you can pull the pipe of of the way of the tranny trap door.
Old Jun 22, 2014 | 10:22 PM
Guntoter's Avatar
Guntoter
I have no doubt someone will come on here and tell you they change clutch cables all the time and never remove the exhaust, but the truth is unless you can get the exhaust out about 6 inches, it needs to come off. Monkeying around and twisting and turning and pulling on stuff to avoid removing the exhaust will most likely end up with a leak at the cable, cover, exhaust or all of them together.
Old Jun 22, 2014 | 10:33 PM
Crex39's Avatar
Crex39
I used a ball end allen on the top two bolts that were covered by exhaust and had just enough clearance. This was with factory exhaust on a 2006 Electra Glide.
Old Jun 23, 2014 | 08:35 AM
CyGlide's Avatar
CyGlide
With my dresser duals I just loosed the rear cylinder pipe up and that gave me enough clearance to get the trap door off.
Old Jun 23, 2014 | 08:51 AM
Dice297's Avatar
Dice297
Loosen the flanges and the exhaust bracket under the trap door....take the heat shields off and it should give you enough room to get to it...just did mine a few months ago that way....same year...flhtc.
Old Jun 23, 2014 | 10:10 AM
gliderman's Avatar
gliderman
Just did clutch cable last week on 13' Road Glide with stock exhaust. Remove the 2 heat shields at rear cylinder and along tranny trap door. Use good quality long ball allen head wrench to get at the 2 lower bolts on the trap door. Remove the other 4 bolts on trap door, remove door and gasket, remove cable and route new cable in same manner. Reassemble using new gasket on trap door, tighten bolts in proper sequence per manual. You will not be able to apply torque wrench to 2 lower bolts but not a big deal at all. Just tighten them down good with the long ball. Adjust clutch, job done... PM me if you need any help with this...
Old Jun 23, 2014 | 10:20 AM
Jags93's Avatar
Jags93
I was able do it with a shortened Allen wrench by only removing the shield, did not have to loosen exhaust at all. No need to use a torque wrench. If your concerned about that set up a bolt in a vice and use your torque wrench there to get a feel for how much resistance is needed, practice the correct amount of force by hand.
More than likely the gasket will be reusable too.
Steve
Old Jun 23, 2014 | 05:17 PM
fenwick's Avatar
fenwick
tks for all the reply going to give it a shot tonight. want to get it done so I can try new bars
larsfum
EVO
Sep 17, 2016 05:18 PM
ZenGlide
Mar 7, 2014 07:56 PM
berndog
Jun 3, 2013 01:22 AM
marvo75
May 6, 2013 08:30 AM
shaun929
Mar 3, 2012 10:11 AM
