04 clutch cable replacment.
Old May 5, 2013 | 10:03 PM
marvo75's Avatar
marvo75
Default 04 clutch cable replacment.
Gotta swap clutch cables on my 04 road glide, does the exhaust have to come off?
Old May 6, 2013 | 05:40 AM
kyote's Avatar
kyote
only if you can't get to the transmission cover bolts with it still on.. if ya can't..then yes..
Old May 6, 2013 | 05:55 AM
Notgrownup's Avatar
Notgrownup
More than likely... you may get away with just getting it really loose
Old May 6, 2013 | 08:26 AM
Skip's Avatar
Skip
If yours is like my 2005 flht, it makes it a lot easier with the exhaust dropped. I fooled around with trying to replace the cable w/o removing exhaust, could not get a good grab on the trans cover bolts.
Old May 6, 2013 | 08:30 AM
Sauceman's Avatar
Sauceman
It takes less than 20 mins to remove the stock exhaust and it makes it soooo much easier to remove the transmission cover. If you have aftermarket pipes without those heat shields it takes even less time
cheers
fenwick
Jun 23, 2014 05:17 PM
mrgr8ness
Apr 28, 2014 01:50 PM
ZenGlide
Mar 7, 2014 07:56 PM
berndog
Jun 3, 2013 01:22 AM
RCNewton
Jul 1, 2005 02:52 AM
