Installing new clutch cable on RKC
Old Mar 2, 2012 | 07:32 AM
shaun929's Avatar
shaun929
6th Gear
Default Installing new clutch cable on RKC
I have a 2000 RKC and am putting 16" apes on. I've gotten to the point where I need to take out the old clutch cable and put the new one on. It looks like I'll need to take the exhaust off in order to get at the cable. Is this the only way to do it or is there an easier way?
Old Mar 2, 2012 | 07:40 AM
HemiGlide69's Avatar
HemiGlide69
Typically you have to remove your exhaust, I did.
Some on here have said that they were able to just loosen the exhaust (stock) to access the trans side door.
Good luck
Old Mar 2, 2012 | 07:51 AM
cubalz's Avatar
cubalz
Getting the exhaust off is easy, just spray the studs with penetrating oil like Kroil etc once a day for 3 days and go easy on the wrench and you will be fine. I have had the exhaust off of every bike I have ever owned and never had an issue following the above steps. FYI, WD40 is not a substitute for an good penetrating oil.
Old Mar 2, 2012 | 08:00 AM
WSRyda05's Avatar
WSRyda05
I just did this one my 05 Road King 3 weeks ago when putting 14" apes on my bike. Yes you will have to remove the exhaust if you have the factory exhaust system on it. You have to be able to get the clutch cover off and the exhaust is blocking 2 of the screws you need to take out. The mufflers will have to be removed as well on both sides. You also have to remove the right side footboards.
Get the manual and it will be much easier. The manual breaks it down step by step.
Old Mar 2, 2012 | 08:15 AM
rayzor931's Avatar
rayzor931
+1 on removing exhaust and floorboards. I've got 16s on my 2005 RKC and it will end up being easier with everything outta your way. The clutch cable isn't difficult to replace but don't get in a hurry. You'll need a good set of retaining ring pliers and make sure you take a good look at the inside of the clutch housing before disassembly even if you have a manual. I've learned from experience!
Old Mar 2, 2012 | 08:25 AM
WSRyda05's Avatar
WSRyda05
+1 on not getting in a hurry. and +1 on a good penetrating oil, it makes a difference. Oh and have a oil pan under the bike once you take the tranny cover off, because you will loose fluid, so it will be a good time to go ahead and change your tranny fluid if it needs it.
Get a friend to help you also, it will save you some frustration. I learned the hard way trying to do it myself. Once I got a friend to help it was done in a breeze.
Old Mar 2, 2012 | 08:35 AM
WSRyda05's Avatar
WSRyda05
One other thing, go to you local HD dealer and buy a new gasket for the tranny cover since your gonna have to open the casing. You don't want any leaks after you install everything.
Old Mar 2, 2012 | 08:39 AM
fishn4life's Avatar
fishn4life
Just did this few weeks ago, just my experience here but I did NOT remove my exhaust. I did remove the mufflers and loosened the exhaust bolts about half way, there is the one rear allen that was a little tricky on the clutch cover, but to newer your question - yes you can do it w/o removing exhaust.
Old Mar 2, 2012 | 08:41 AM
fishn4life's Avatar
fishn4life
I also switched out gasket and drained/replaced tranny fluid
Old Mar 2, 2012 | 09:07 AM
WSRyda05's Avatar
WSRyda05
+1 I did the same thing. Simply loosened the exhaust enough just slide it back enough to get to the rear allen. Definitely didn't have to remove it completely. You will see once you get it loose it can move freely.
