1997 ultra glide lowering question.
Old 08-10-2018, 04:44 PM
Baggerchick's Avatar
Baggerchick
Baggerchick is offline
Default 1997 ultra glide lowering question.
I have a 1997 electra glide ultra and I absolutely love this bike. I sent my seat into mean city and had them drop me an inch and move me forward an inch. I also had it dropped an inch in the rear shocks. I sit flat footed with a decent bend to my knees but feel another inch would be better. My question is has anyone done this, hows the ride and what shocks are the best for this for ride quality.
Old 08-10-2018, 05:19 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Wink
The best thing you can do IMHO is buy yourself a pair of thick-soled or higher heeled riding boots. Most of the lowering things people do compromise the bike in some way, such as reduced ride comfort or poorer cornering clearance. You've already done more than enough to your bike, so make your legs a little longer!
Old 08-10-2018, 05:20 PM
bentparts's Avatar
bentparts
bentparts is offline
Dropping another inch in the rear shocks will leave you with 1 inch of suspension travel in the back, ride will be pretty stiff. It will also change the steering geometry but that may not be too big a deal. You could try adding a set of lowering blocks to your swingarm but most will cause your shocks to interfere with the bags. I agree with grbrown, thicker soled boots.
Old 08-10-2018, 07:47 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
No no no! Do not use lowering blocks. They have been known to crack the swingarm. Bad juju.
Old 08-10-2018, 07:56 PM
1997bagger's Avatar
1997bagger
1997bagger is offline
Received 1,695 Likes on 856 Posts
1" shock drop will live if you don't run heavy, more drop with lowering brackets will put the tire in the fender plus it isn't recommended to run them with pre 1999 bagger swing arm. Been running 1" drop Progressives for around 8 years and the ride isn't the best due to a heavy spring, shorter shock travel, learned to live with it. Been recently starting to look at some custom built Ohlins to get the low stance and a better ride, it is possible but takes some coin.
Something to check out is Street Glide 12" take offs, many many 12" air shocks out there, some of the new adjustable shocks are available taken off Street Glides offering a low budget lowering set up. Then goes up with entry level Progressives, better Progressives and Ohlins, 12" shocks can work, just hard to blend running loaded and running single out of the same 12" shock.
Old 08-11-2018, 04:15 AM
grbrown's Avatar
grbrown
grbrown is offline
Talking
Lady riders get it easier than us chaps, when it comes to reaching for the ground!
Old 08-11-2018, 06:45 AM
Newharleylover's Avatar
Newharleylover
Newharleylover is offline
Received 1,165 Likes on 456 Posts
I had a 2009 RK before the Electra Glide I have now. The seat height on the Electra Glide is approximately 3 in shorter than the RK was and I ground the bottom of the boards on the RK a fair amount and it was stock height. With the Electra Glide I take the lower stance into account and adjust my riding style to suit. The lower you go the more risk there is of grinding your boards off or possibly wiping out if you're an aggressive rider.
bentparts (08-11-2018)
Old 08-11-2018, 03:06 PM
Baggerchick
Thank u for all the tips, I am 5'7 at 130 so I doubt ride quality as far as bumps go would be to bad with lowering a little more. Dont aggressively ride either. Thinking I will try the boots first and look into progressive as mention. The boots I have are hd but not thick soled or high. Having the lowered center of gravity would help me with control at slow speeds and stops. I dont need much more lowering.
Old 08-11-2018, 03:11 PM
bentparts's Avatar
bentparts
Default lowering shocks
I believe she said it's already been swapped over to the 1 " lower shocks. Another inch will basically give her 1 " of travel. Might as well be a rigid.
Old 08-11-2018, 03:13 PM
bentparts's Avatar
bentparts
Default Floor boards
It's when your into grinding the mounts down it can get scary. They don't fold like the boards.
Quick Reply: 1997 ultra glide lowering question.
