Dry clutch belt primary
Need information please ,'!!!! Given a bike some years back, it’s an odd duck for sure. Frx aftermarket frame, and crankcase, best I can tell a 94 cruiser primary, etc etc.well a friend says primary leakin good and knows this primary so let’s replace drain plug gasket and refill, Hum sounds ok so 30 minutes ans a few bears later it’s done. Bike sits a day then I go for a spin, clutch seems to be slipping and not wanting to hit 4th or 5th. , park it over night and oil from primary everywhere about a 32oz puddle. Pull clutch chain tensioner and there sits a ferry in belt !!!! Oh yea lm torqued at my buddy, didn’t even check things....anyway can I clean clutch pack and belt with brake cleaner and is that an ok fix or am l out big bucks....help please
I trusted someone said he knew about this primary. Clearly he pulled the plug replaced o ring and dumped oil in. After l rode it I knew there was a problem. I found the chain tensioner plate gasket leaking while bike was on kickstand so l leaned it on a block on the other side and pulled the tensioner plat only to see a belt, that’s it period. Previous oil leak was the rear wheel chain Oiler turned up to high. I’m not a Harley Mechanic nor do I claim to be. It’s my experience **** happens if you don’t do things yourself. Damage is done, friend is told off and I need to figure out the fix
