Power!
Old 05-26-2019, 06:40 AM
alden83's Avatar
alden83
alden83 is offline
Stage III
Default Power!
Hey guys! No crank no start. On accessory I get power to speedo light only, on ignition I get nothing. Battery good, fuses/relays good, ignition switch cleaned and tests good. Checked for bad grounds and pinched wires in common areas. Checking starter next. Why is my speedo bulb under power when everything else is dead? Seems weird
Old 05-26-2019, 06:51 AM
WP50's Avatar
WP50
WP50 is offline
Received 1,699 Likes on 1,154 Posts
What kind of bike ?????
WP
Old 05-26-2019, 08:17 AM
alden83's Avatar
alden83
alden83 is offline
Stage III
WP
1998 Softail custom fxstc
Old 05-26-2019, 09:34 AM
Beemervet's Avatar
Beemervet
Beemervet is offline
Check the kill switch.
Old 05-26-2019, 10:28 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
Kill switch is my first thought as well.
Old 05-29-2019, 07:40 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
Checking starter?.... Exactly how would a starter cause this issue of no power when ignition switch is on?
Forget about the starter and keep your wallet in your pocket, and do some systematic troubleshooting, cheap easy stuff first.
Make sure the battery is fully charged, take it to an auto parts store and have it load tested.
Clean all battery connections.
Once this is done, get your voltmeter and check voltage at the fuses with ignition switch on (read voltage at each side of fuse).
Let us know what you find.
Old 06-07-2019, 06:15 AM
alden83's Avatar
alden83
alden83 is offline
Stage III
Default Found it
Negative battery cable was broken under the heat shrink, thanks y’all.
Racepres (06-07-2019)
Old 06-07-2019, 06:58 AM
texashillcountry
Dirt don't hurt
Now there's a problem that doesn't come along everyday.
Congrats on finding it.
Shepherd1972
08-04-2018 03:03 PM
realjewel69@gmail.com
General Topics/Tech Tips
17
12-18-2016 10:58 AM
jack56
12-18-2012 11:28 AM
?roadking?
11-12-2012 01:45 PM
mjh
Electrical/Lighting/Alarm
01-20-2011 08:36 PM
Quick Reply: Power!
