part numbers
Old Jun 24, 2015 | 09:07 AM
utterstan's Avatar
utterstan
Default part numbers
was wondering if anyone new the part number for 91 flhtc electroglide stator I would be thankful.
Old Jun 24, 2015 | 09:16 AM
14GuineaPig's Avatar
14GuineaPig
Try looking here:
http://www.granitestateharleystore.c...-90633-H020035
Jchaiyo's Avatar
Jchaiyo
JP cycles, vtwin, Dennis Kirk list goes on
Old Jun 24, 2015 | 10:29 AM
DeputyLoud's Avatar
DeputyLoud
29970-88A
http://partsfinder.onlinemicrofiche....TAGE REGULATOR
Curous why you ask? I have the same model and year and have had an issue with the connector on the stator to regulator connector being loose. I had to tighten up the connections, and also got a retainer bracket from ebay to stop it from happening again. Here's a pic and link of that.
http://www.ebay.com/itm/271734996227...%3AMEBIDX%3AIT
Old Jun 24, 2015 | 11:31 AM
Yankee Dog's Avatar
Yankee Dog
Get the one from cycle electric. High quality american made and the plug is more robust. YD
Old Jun 24, 2015 | 02:09 PM
IBDAGRIZ's Avatar
IBDAGRIZ
29970-88A
I eliminate the plugs on these older style of regulators and wire them directly to the stator with a connector on the outside of the case. I remove the rubber plug from the stator and solder longer wires to it, heat shrink 'em, and run them thru the case. I fill the plug hole with silicone to seal it and add the connectors on the outside. Much better connections that don't vibrate loose.
Griz
Old Jun 24, 2015 | 05:33 PM
Yankee Dog's Avatar
Yankee Dog
Originally Posted by IBDAGRIZ
29970-88A
Griz
I like this idea, and I assume the solder and heat shrink connections are in the actual primary and not visible from the outside of the bike? I guess the sealant lined heat shrink would be perfect for something like this situation.
How do you make the silicone "filler" look good in that plug hole? And how does that silicone hold up? I assume you use something like black rtv adhesive sealant?
Got a pic? I would love to see one. Thanks, YD
Old Jun 24, 2015 | 05:44 PM
utterstan's Avatar
utterstan
thank you I got anew one at a Harley dealer and its a 29970-88D so it is the wrong 1 well I guess I will use the dremell on it
Old Jun 24, 2015 | 05:48 PM
utterstan's Avatar
utterstan
nice scoot deputyloud mine is the same color
Old Jun 24, 2015 | 06:32 PM
14GuineaPig
That part number should be the correct one for your bike. The letter "D" means it's the fourth revision of the part.
29970-88D STATOR $121.35
