Mystery Harley help to identify please
Thanks guys I'll have to buy an 89 starter and hope it fits. It will take to much work and money to find the parts the 83 came with this is what I bought and I found out after its was parts from a 89 after the starter crapped out. And idea what the heads are from it says jegs on the very to but I didnt think they made heads it's had 3 bolts flange I pulled off some number casted on them 030482 on one and the other says 0672 no clue what that means.
This is good advise. Look for a starter repair shop in your area and give them a call. That way you know it will fit, know where to go locally if you have a problem and save a few bucks in the long haul.
Received 14,308 Likes
Starter repair shop or a place that rewinds electric motors should be able to rebuild your starter. When you have parts from different things, it is often easier to fix what you know works rather than try to buy something new that may or may not work.
In this case, your engine is not an Evo, but your primary and who knows what else is newer than your engine.
I just happened to notice your clutch is different from what I had on my 89 FXR.
Also your starter looks like the ones in those E-Bay links
Part# 31570-89A
Check this out http://www.harley-davidson.com/store...e-14kw-starter That fits 1994-2008
This helps vvvvv
