Fork oil change going disastrously wrong
#51
Received 4,618 Likes
#53
#54
Not sure why you removed the headlight and nacelle to change the fork oil. On a 1998 simply remove right saddlebag. Attach low volume pump to the front Schrader valve. Place catch pan below drain hole. Remove drain plug. Pump low volume pump till old oil is out. Turn handlebars to the other side. Repeat. To fill, you place your Mityvac on the front valve. Attache a small hose to the front drain plug. Make sure the other side is capped off. Put the hose into the fluid, and pump the Mightyvac till all of the fluid is is the fork. repeat on other side.
FORK OIL IS DONE!!!!
#55
Received 4,338 Likes
