97 road king engine light on and missing !!
Old 06-20-2017, 02:14 PM
shawboat67's Avatar
shawboat67
shawboat67 is offline
6th Gear
Default 97 road king engine light on and missing !!
hey guys i need some help here please, so last year i bought a 97 road king of a friend of mine and right away the engine would come on but go out right away, would do this off and on but run good, now the engine light is on steady and runs rough and is burning very lean, the spark plugs are black and exhaust is black i put new plugs in thinking they were fouled but no change, it is fuel injection and have heard nasty things about that system, is there anywhere i could look or any suggestions ? as the mechanic i was talking to here in kamloops can't look at it for at least a month, thanks
Old 06-20-2017, 02:26 PM
Raineman's Avatar
Raineman
Raineman is offline
1st place I'd ask is in the EVO forum here.
Old 06-20-2017, 02:31 PM
shawboat67's Avatar
shawboat67
6th Gear
Default how do i log into cvo
can't seem to find cvo on here !
Old 06-20-2017, 02:50 PM
Raineman's Avatar
Raineman
Raineman is offline
EVO forum. Not CVO...E.V.O. as in Evolution engine which is what you have in your bike.
https://www.hdforums.com/forum/evo-classic-models-84/
Old 06-20-2017, 03:38 PM
Buelligan666's Avatar
Buelligan666
Buelligan666 is offline
Black plugs and black smoke is the opposite of lean. The EVO section of the forum would be your best bet.
Old 06-25-2017, 07:39 PM
carlgrover's Avatar
carlgrover
carlgrover is offline
Received 2,197 Likes on 1,272 Posts
You need to find out what fault code you have that is causing the check engine light to come on. There are directions in here in the EVO section for how to do that. After you get the code, the same place you get the directions from on how to retrieve it should have a table to look up the fault.
Basically, you turn the ignition on/off on/off on then leave it on and count the number of times the light blinks.
carl
hyrax222
EVO
09-04-2018 06:28 AM
psoldmann
Engine Mechanical Topics
04-24-2017 01:28 AM
psoldmann
04-23-2017 09:25 PM
panman4977
06-15-2015 01:19 AM
dennis pitts
01-03-2012 08:12 AM
Quick Reply: 97 road king engine light on and missing !!
