Vance & Hines baffle rattle
Old 06-24-2017, 10:25 PM
Crashone's Avatar
Crashone
Crashone is offline
Default Vance & Hines baffle rattle
I picked up a pair of V&H slip on mufflers that seemed to be in good shape however now that they are installed the baffles are rattling around. There is a screw on the bottom holding the baffles in at the outlet end. The rattle sounds like it is happening at the inlet end where there are no screws.
How do I fix this? Pull them off, drill a hole and through bolt them at the inlet end?
Old 06-24-2017, 10:31 PM
Prot's Avatar
Prot
Prot is offline
Received 14,260 Likes on 6,241 Posts
You could remove them and install big city thunder baffles.
Old 06-25-2017, 06:23 AM
RedHogz's Avatar
RedHogz
RedHogz is offline
Pull them and see if a simple 'muffler tape' wrap around the inboard end will stop the rattle.
Old 06-25-2017, 10:39 AM
WP50's Avatar
WP50
WP50 is offline
Received 1,717 Likes on 1,167 Posts
Are the baffles wrapped ?
I have used stove rope to wrap a baffle and took out a baffle rattle toward the front.
WP
Old 06-25-2017, 11:13 AM
Crashone's Avatar
Crashone
Crashone is offline
Thanks for the replies, I'll pull it off and see what I can do.
Old 06-27-2017, 09:45 PM
Crashone's Avatar
Crashone
Crashone is offline
I checked it out and the baffle would rock back and forth a little causing the noise I could hear. I tried to tighten it up but it did not hold so tonight I applied a little JB Weld over the places that moved. I'll see how well this fix works in the morning.
Old 06-28-2017, 09:20 PM
Crashone's Avatar
Crashone
Crashone is offline
Worked just fine so far, at least it is still holding after the 80 mile commute to work. I like the sound of these better than the ones I had on it. A good rich deep tone.
Old 07-21-2017, 09:43 PM
zlaneb's Avatar
zlaneb
zlaneb is offline
Default This is BS - VH needs to address the rattle issuess!
My VH slip ons are driving me nuts. I've never had anything like this with past pipes. I have got to fix it - it sounds like they are rattling around in the canister. D
Old 07-22-2017, 05:38 PM
Crashone's Avatar
Crashone
Crashone is offline
Yea mine is back after they warm up. I need to pull it off and see what's up.
Old 07-24-2017, 01:27 PM
IRON1250's Avatar
IRON1250
IRON1250 is offline
I have been chasing a rattle for awhile. After reading this post I realized it started right around the time I had to put the baffles back in to get it inspected. I'll have to look into that!
Kem48
07-04-2019 12:52 AM
stinkerbill
08-20-2017 06:21 PM
steelerdude1
2014-2023 Touring Models
08-23-2016 10:25 PM
SSTuner
05-26-2012 07:59 AM
falsealarm
05-14-2010 06:16 AM
Quick Reply: Vance & Hines baffle rattle
