Wego file
Old 07-22-2017, 07:16 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,879 Likes on 3,344 Posts
I'll have to get my laptop fixed. Daytona does not offer the software for Mac and I can't download the software to my Android phone..... Sorry I can't help at this time....
Old 07-22-2017, 07:30 AM
1997bagger's Avatar
1997bagger
1997bagger is offline
Received 1,692 Likes on 853 Posts
Originally Posted by yellowstone kelly
You have to have the Wego Log software installed on your computer to display the file as a graph.
Without the Wego Log software installed on your computer, the zip file extracts to a text file that makes no sense and doesn't show any graphed results.
You can supposedly get the software from this website:
http://www.daytona-sensors.com/
I took a quick look and I think you can download the software from the choices under the "Tech Center" header, but I wasn't able to tell easily which software was the "Wego Log" software needed.
They have the software, the recorded run isn't being loaded to the file for viewing as it should, have to go find it.
Still not thrilled about the newer software not allowing a run to be spread out like a dyno graph, makes it harder to read.
Old 07-22-2017, 07:34 AM
98hotrodfatboy
Didn't realize they changed it. My original disk should have all the proper functions to expand....
Old 07-22-2017, 07:49 AM
1997bagger's Avatar
1997bagger
Just went through your whole recorded graph, leave it alone. For a carb the numbers are consistent with the cruise and wide open throttle pretty much spot on, it should run well. 13.2 average at WOT and 13.8-14.2 in cruise areas, ride it and don't overthink this.
Old 07-22-2017, 08:11 AM
1997bagger's Avatar
1997bagger
Did some more work, was able to cross the graph into my old software and spread it out. Copied a WOT throttle run and a long cruise run, easy to read and more accurate, the graphs can be expanded by clicking on them and dragged for better viewing
Your long cruise was at 4000 rpm's, you are really cruising
Old 07-22-2017, 08:31 AM
1997bagger's Avatar
1997bagger
Here is reversion on the current graph, decel off higher rpms to 4000, the red line is the rpms falling off and the green is the AFR's climbing to 16.4 by pulling air backwards into to cylinder thru the exhaust and not enough fuel to combat it but not much can be done about it except a more restrictive exhaust. Install a more restrictive exhaust to battle reversion and all of the AFR numbers will richen and may have to rejet, the graphs show just how critical and touchy tuning can be
Old 07-22-2017, 09:57 AM
98hotrodfatboy
Great job bagger.. thank you for the assistance...
Like you said the first two graphs are spot-on I wouldn't touch a thing and ask for the D cell yet that's going to happen with that RB pipe you're going to see it like that.
There's not enough back pressure to decrease the amount of reversion there.
So John you're spot-on I wouldn't touch a thing you're looking real good man. You anoint gonna get much better than that....
Old 07-22-2017, 10:50 AM
nibroc's Avatar
nibroc
nibroc is offline
not very computer literate
Old 07-22-2017, 11:55 AM
1997bagger's Avatar
1997bagger
My older software allows me to spread the graph, sent the old software to Harold and he was able to spread the graph. Don't know why Daytona did away with it
Old 07-22-2017, 12:02 PM
1997bagger's Avatar
1997bagger
Great job badger.. thank you for the assistance...
If that is the RB pipe on it, I noticed a good thing, shifting gears in a hard accelleration has no change in AFR's meaning no reversion. If you look at the WOT graph, a shift is in it earlier with roughly a 3000 rpm drop and the AFR's stayed the same
Quick Reply: Wego file
