1987 Evo motor build up questions
Hi guys,
My MC Bro is debating whether to buy a new Evo motor for his FXR or build it up. If he kept it at a stock 80 inch motor but wanted better HP and Torque. What cam would someone recommend as well as what kind of cylinder heard work would anyone recommend? He has a brand new Mikuni carb on the bike as well as a high flow air filter. Or would going up to the 85 inch revperf piston and cylinder package be a better move? What is the largest he could go with if he went with S&S?
Received 7,787 Likes
Inevitably there are various options, depending on the condition of his current engine. If he's talking of doing headwork we have access to HDF sponsor Hillside Cycles, who have proven Evo builds that will give a great boost in performance. Check out their website, as they can provide a one-stop-shop of headwork plus any other work needed, parts etc.
On the replacement engine front, quite a few of us have S&S engines, a 107" in my case, several of the later 111", also 124", as well as Stingray's 113". In the case of the 107/111 a beefed up clutch will be necessary and in my case I have also added a bigger starter motor. I replaced the primary chain and compensator as that had developed sharp teeth, showing how it had worn. I bought my 107" as a complete engine, with ignition system and carb. The exhaust can give real benefits and I have swapped my original TDs with a Supermeg, which is sublime.
Received 4,338 Likes
Instead of a beefier starter you can simply change the pinion and ring gear to a 10-84 set up.
Mine is a Rivera Primo and works great but a friend put on a Compufire and never could get it to work right then he changed that for a Baker and it works fine.
I put Barnett Kevlar fibers in my clutch and they hold my 111 just fine.
It all depends on what he wants to do with the bike. Does he want speed? Or just stability?
I'm 280 @6' 1", just a big boy. My stock '98 needed a *lot* of room to pass when going at speed (55 mph and faster). Got tired of that since it never worked out as often as I wanted/needed.
I looked for torque, to get my big *** and the bike moving *now* and with some oomph, so I went with the EV13. Now, I can pass whenever I want at *any* speed. I won't win any races, but that's not what I give a crud about. All the bikes in the world can beat me in a race and I wouldn't give a rats *** about it. I wanted and needed dependability and for the bike to do what I needed it to do when I wanted it to do it. I also got to keep the 45 mpg's with the EV13, at least until 75 mph, any faster than that and the mpg's start to go downhill, heh.
There's a lot to be said for a proven combination of parts, by that I mean the components a respected engine builder would use and warranty. To get an idea of potential performance I like to look at the Wood Performance Dyno page, you'll get an idea of what is possible with different displacement evo's.
http://www.woodcarbs.com/dynoruns.htm
ShadowforNow (03-27-2019)
