Front Cylinder Blown Head Gasket - 97 WG
98hotrodfatboy (02-20-2024)
Started back putting the front cylinder back on. Pushed it down and it seemed hung up about 3/4 of the way. Pull cylinder up to see what issue might be and...pulled cylinder off the piston. My dumbest error.
IIRC, I can't reinstall what I have.
I need new rings and the cylinder honed, I believe. Anything else so I can keep my f***ups to a minimum.
EDIT: Does one of those stud threads (the pic on the right) look a little galled?
The current rings will likely be as good as they were before the tear down, but it's lot of work to go back in later. If it were mine, at 50k miles, I'd mic the cylinders and re-ring and do a valve job with new valve stem seals.
Follow the Cometic procedure for torquing the head bolts. And lube (lighty) the head bolts (flange and threads).
Paul
Paul
There is no reason to re-ring and re-hone just because you pulled a jug by accident...many will tell you otherwise but they are just plain wrong.
The following 6 users liked this post by Spanners39:
djl (02-25-2024),
Firedude2 (02-21-2024),
pgreer (02-20-2024),
s-glide76 (02-21-2024),
Scottyxbones (02-21-2024),
and 1 others liked this post.
Make sure your gaps are lined up and go for it
Been there done that
WP
The piston was not originally removed from the cylinder when the head, cylinder, etc. were removed.
I just pulled the cylinder off...would the rings have moved just from this action? I understand it's probably a good idea to check.
Thanks for the heads up on the tool for the rings.
Spanners39 (02-21-2024)
I wouldn't re-ring or re-hone unless you had blowby/low compression issues prior to the teardown. Check the rings for damage, check the cylinders for scrapes, remove any carbon deposits, go ahead and reinstall. Well, mic the cylinders first and see if its necessary to bore out +.005, if not then reinstall. Note that the cylinders deform as much as .003" when torqued down properly so there's your margin, if you want to be **** about it use torque plates then measure. Or have a reputable machine shop measure for you
