extra regulator ground wire?
Old Jan 29, 2024 | 07:17 AM
kino44's Avatar
kino44
Default extra regulator ground wire?
I have a 1984 FLTC EVO using a 32 AMP system instead of 22 just wanted to get some advice on grounding regulators I have been plagued with charging issues lately my regulator is mounted to the front bracket paint is removed and it shows a good earth from battery the whole frame is good when testing from POS battery term to frame gets the same reading from battery as to frame so my question is have any of you added an extra ground wire from regulator up to NEG battery term? would it hurt any? I do use the extra ground wire pigtail which is also grounded to frame wondering if running it up to NEG post would be better? I also have been known to go chensy on reg and stators I ordered new ones from cycle electric I hear they are best
Old Jan 29, 2024 | 07:30 AM
86glider's Avatar
86glider
I have also upgraded mine to 32 amp system. If you’re reading at frame connection I would think you’re good and no need for another ground. I like having a voltage gauge to keep an eye on my charging system at all times. Going with Cycle Electric is a good choice.
Old Jan 29, 2024 | 07:37 AM
kino44's Avatar
kino44
Ok I figured as much just curious like good insurance
Old Jan 29, 2024 | 08:41 AM
Yankee Dog's Avatar
Yankee Dog
Extra ground wire can't hurt either
Old Jan 29, 2024 | 09:23 AM
t150vej's Avatar
t150vej
Here's best place to wire the extra ground wire. (the stator plug has been modified) hat tip YD.
https://www.hdforums.com/forum/evo/1...l#post20724549
Old Jan 30, 2024 | 08:24 AM
kino44's Avatar
kino44
yea I have of doing things like that cant hurt thanks t150vej
Old Jan 31, 2024 | 02:40 AM
kino44's Avatar
kino44
Default stator plug
I see guys doing that to their stator plugs only problem with that is you cant test stator or regulator if you have charging issues mine has a flat piece of metal that firmly presses up against it to keep it from coming out I also take a tie strap and wrap it around the outside of the regulator plug
Old Jan 31, 2024 | 05:41 AM
johnjzjz's Avatar
johnjzjz
Evo regulators 32 amp has a ground mounting screw thread under the reg and a cut out for the wire to travel to the mounting bolt
Old Feb 1, 2024 | 05:51 PM
98hotrodfatboy's Avatar
98hotrodfatboy
John beat me to it and I always use it.. Just a short wire with 2 electrical eyelets and star washer to aid in the grounding that is attached between the regulator mount screw nut and frame.. Also check all other chassis ground.. Very important..
Old Feb 2, 2024 | 07:29 AM
86glider's Avatar
86glider
On another note, the plug connector at the case is a weak point. Last stator replaced I made a soldered connection at the stator leads and fished them thru the connector plug , then made a more solid connection.
2012SG_Man
Audio Systems
Feb 27, 2023 01:42 PM
Taylor68
Ironhead
Aug 13, 2013 05:24 AM
PowerDude
Sep 4, 2012 10:59 PM
Randall
Jun 9, 2011 12:17 PM
HSMaxim
Flathead
Mar 22, 2008 09:06 PM
