Brake light problem
Old Mar 2, 2010 | 10:20 AM
yank's Avatar
yank
Default Brake light problem
I installed a custom tail light a few years ago. it has worked fine until recently when i tore my bike apart. I reconnected the same wires and now the running lights work but not the brake light. It has three wires black blue and red. i tried changing the wires around but to no avail. where else can i look to try to determine the problem. my bike is a 1996 FLSTN.
Old Mar 2, 2010 | 12:12 PM
t150vej's Avatar
t150vej
Not that familiar with Softtails... but on most, the wire from the light goes to the rear brake light switch and at the terminal is crimped together with the front brake light switch wire. Other side of the rear switch is incoming power. I would start there checking for voltage.
Old Mar 2, 2010 | 11:20 PM
alaskajeff's Avatar
alaskajeff
If you can pull it back off try testing it directly to a battery to see IF it's actually the problem. Then go from there. The red should be the run wire and the blue should light up the brake light. If it works then you can look elsewhere.
Damien Bessent
Sep 20, 2022 03:36 PM
Statefarm-outlaw
General Topics/Tech Tips
Jul 6, 2017 11:13 PM
henwy
May 20, 2013 04:31 PM
theoapodaca
Feb 21, 2011 01:15 PM
JustDave71
Wheels/Tires
Nov 1, 2009 11:46 PM
