1988 FXSTS Signal Lights
I've got a problem with my signal lights and can't come up with a solution. When I push either signal light switch, it will run for approx. 7 seconds then shut off automatically. If I do a quick left then right both lights will flash in 4 ways for approx 7 sec. again then shut off. It looks like the PO did some wiring himself (very shotty in rest of bike) but I'm having a heck of a time finding out how the wired would have been run stock. When you guys hit your signal lights, what keeps power running through the circuit and then kills the circuit when you hit the signal light again. Also, what do the old lean switches look like, I know my bike shouldn't have one but there is a black puck? with some wires running into it but the puck itself has a big crack in it, not sure what this is. Thanks again.
Stock your bike didn't have self canceling T/S, somebody added an aftermarket doo-dad. Stock it just comes on when you push the button, goes off when you don't. Simple, easy. The Harley service manual has wiring diagrams in the back, get one if you don't have it and it can show you how its supposed to be wired. JMHO, YMMV, etc.
Bob
Bob
