Delayed crank when hitting starter button
Old Sep 11, 2007 | 05:03 PM
davp22's Avatar
davp22
6th Gear
Default RE: Delayed crank when hitting starter button
I have a 1992 FXR with the big bore kit and Screamin' Eagle parts (bought it from the dealer already modified), and it sometimes pauses when I start it. The salesman told me that was normal due to the high compression from the engine modifications. This being my first HD (I traded in a 2003 Vulcan 1500 Classic), I figured he knew what he was talking about. ????
Old Sep 12, 2007 | 01:06 AM
alaskajeff's Avatar
alaskajeff
My 92 was doing the same thing.A 3 year old battery was the culprit. Then it started doing it again with the NEW battery!! Then I found BOTH the terminals came loose, I tightened them up and it starts like new again.
Old Sep 12, 2007 | 04:48 AM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
I once bought a new HD battery that was defective. Talk about frustrating - caused me to keep looking for something else.
I don't know if it's true, but an HD mechanic told me that if you don't fully charge a new battery before using it, it may never take a full charge. Is that bunk or is it true?
Old Sep 12, 2007 | 07:10 AM
glide's Avatar
glide
Any battery should be fully charged before using it.
The cranking problem can usually be traced to resistance in the battery cables higher than normal.
Welding cable flows more amps than standard battery cables of the same size because of the increased strands of smaller diameter and it is also more flexible than standard cables.
Replace the battery cables or make a replacement set of battery cables out of welding cable and watch the starter problem disappear.
Old Sep 24, 2007 | 06:10 PM
gigiflip's Avatar
gigiflip
OK, I've read about this and researched it a bit as well. IIRC, Donny Peterson mentions this on his website. It basically boils down to this. The hesitation is due to the initial ignition of the air-fuel mix in the combustion chamber. The engine is not spinning over very fast and the pressure build-up in the combustion chamber, as ignition occurs, is enough to cause a slight hesitation in the starting cycle. It's nothing to worry about. However, if you are worried about it then you can change to an aftermarket ignition module. These will generally allow the engine to spool up to a higher RPM before igniting the mixture. The higher RPM negates the pressure buildup in the combustion chamberdue to the engine having greater inertia. I believe that the EFI models actually have this feature built into their modules.
Of course, all this only holds true if everything else (as mentioned in this thread) is running as advertised.
As a side note, I actually like the hesitation.
Old Sep 25, 2007 | 12:12 PM
nfe's Avatar
nfe
I had this happening on my '94 Ultra.. I ended up rebuilding the starter.. The stealer had a kit for around $60... That fixed the whole issue.. The only thing is that I can mention; sorry that I didn't read this thread indepth, so I may repeat something, is to replace/check the charge of the battery before hitting the starter, all I can say is it's easy to do, however it takes quite a while!
Old Jun 29, 2008 | 09:25 PM
FLGEEZ's Avatar
FLGEEZ
ORIGINAL: Hackd
FLGEEZ: Since you've got a FI Classic, there could be a voltage drain somewhere. Disconnect the ground from the battery, take a testlight or meter and start checking for a drain. I'd also check that pesky regulator/stator connection. If it's dirty/oily or loose you're gonna get an intermittant connection which will not allow the battery to charge consistently.
A less than fully charged battery will create the symptoms that you are describing. Which is why having the trickle charger on it will not create the same symptom. Battery chemistry is....well it's chemistry. I've been told that an initial load can 'excite' a weak battery into working like a fully charged one. Up to a point. Which would explain why you get the 'wham' as the starter engages. Release the button and hit it again....crank, crank, crank.
Any Electro Chemists out there?
&nbsp\\;
Did have it checked back then, but now... It's Kaput or not depending on wether the Green LED that says 'Don't Worry' is accurate or the lack of 14 volts and indication of 10-11 when it has warmed up is of concequence.&nbsp\\; At this writing I am scheduled for 'away camp' at a local MoCo Service Station.
&nbsp\\;
On the EFI , mine anyway, there is no plug connection at the crankcase.&nbsp\\; Solid wires through the grommet from stator to regulator.
&nbsp\\;
Like they say\\;&nbsp\\; New Battery - $125.00 and change, Stator and Regulator diagnostics - $$Ouch, Sitting at the&nbsp\\; Dealership all day to hear 'We don't understand why, maybe tomorrow'&nbsp\\; Priceless....
Old Jul 2, 2008 | 02:45 AM
johntheone's Avatar
johntheone
My 90 bagger does the same, checked the battery and cables nothing of concern. I spoke to a Harley dealer that came back with a sensible response. He believes it is likely to be caused by the natural aging of the starter motor struggling with the EVO compression. His suggestion was to either replace with a high torque starter $$$ or just treat it as a character of the bike, he was not concerend about the starter failing.
Hope this helps&nbsp\\;
Old Jul 30, 2008 | 12:56 PM
Kramer Krazy's Avatar
Kramer Krazy
My '85 FXEF has done the same thing since I bought it in '93 with less than 17k miles on it. It now has over 101,000, and over the years, the starting has not been affected with a different cam, new starter, new solenoid, new relay, new battery, etc.......that's just the way she seems to want to start. I did notice that cold starts got better when I cleaned all of the starter wire contacts, though.
ksimo32
Electrical/Lighting/Alarm
Apr 5, 2021 07:51 AM
Damien Bessent
Nov 8, 2014 07:26 PM
Locmoss
Sep 4, 2013 08:56 PM
jeffsizemore
Jul 20, 2011 09:39 AM
