I have PROOF that synthetic oils promote EVO leaks...
A 4200 mile run won't need an oil change part-way through.....its grinding around town that kills your oil....I go 5,000 - 6,000 miles between changes....with modern mineral (Dino) oil you can go even more than that quite safely...no wonder the USA is sucking the world dry of oil....you guys are just throwing it away!!!!
Synthetic oil has always been the Houdini of motor parts, it seeks and it escapes, that is why you don't wanna use it in Evos and why it would not stay inside a Shovel or a Pan long enough to lubricate anything ;-)
Received 4,617 Likes
Kinda hate to say this, but my Harley has the only motor that's leaked with synthetic out of a variety of metrics and cages I've used it in. Kind of a shame, got better gas mileage on everything else, and higher top speeds on a couple dirt bikes, but syn doesn't seem to do much for my Harley. And yeah, got a couple leaks to fix when I put it on the jack for a tire change change soon. May go back to dino on the next oil change, even though I think it was age, not oil, most likely for the leaks.
On my 05 WGlide, about 20 k switched from dino to synthetic. at 25k did oil change still synthetic about 26k the leaks started on the top end kept getting worse and worse. finally found a set of Orings for the damn thing after a year of looking, but before i put them on, i decided to switch back too dino to check a rumor about how syn. oil cleans to much. the leaks stopped with the dino oil. it was about 3 weeks and they just stopped. my $.02 on my experiance. results may vary, but dino oil is what i'll run. my 3 quarts a year isn't going to run the world reserves dry.
Yep; my 99 EVO had Castrol GTX 20-50 dino in it up until it had 20,000 miles on it. I changed to Mobil-1 VTwin 20-50 and within 500 miles it started weeping oil from the rear cyl. base gasket. I changed it back to dino, and I now have 34,000 on it with no leaks. Two things I have learned from friends. Always warm up an EVO before riding it. Always use dino oil if you don't want leaks. If you don't mind oil squriting out here and there, do what you want.
