EVO 80 Idle Issue
Old Aug 17, 2012 | 09:13 AM
lieutenant G's Avatar
lieutenant G
Originally Posted by Jim Kraft
If I set the idle to low on my 99 Softail Custom, it will drop out the VOES also, but it won't die. It just idles slower. At a very slow idle there is not enough vacuum to keep the VOES switched on.
Not to hijack, but I thought he VOES was off at idle and turned on when the motor pulls 5-7lbs on it?
Old Aug 17, 2012 | 12:41 PM
Jim Kraft's Avatar
Jim Kraft
The VOES is off when the bike starts, but as soon as it starts and gets vacuum it is turned on and grounds the wire to the ignition module. Under load when the vacuum drops, it turns off, removing the ground to the ignition module. When ever the VOES switches off and removes the ground, it retards the timing. If your bike is idling at around 600 rpm or better, you will have high vacuum, and the VOES will be turned on.
lmz5150
EVO
29
May 12, 2017 02:41 PM
guido4198
Carburetor Related
Jul 3, 2012 04:10 PM
HarleyReece
EVO
20
Jun 26, 2012 06:58 PM
jokenroll
EVO
41
Jun 25, 2012 11:24 AM
nwpwr22
Ironhead
May 30, 2012 03:15 PM
