EVO is EVO is EVO
09-16-2012, 05:02 PM
EVO is EVO is EVO
As long as its a Big Twin EVO, stuff like rocker boxes all interchange right? Like FX's, Dyna's and FL's share the same topend parts?
09-16-2012, 05:37 PM
There are differences in years however. Rocker boxes 92 and later had "toothed" edges to better prevent slippage, older models did not. Can't mix and match older and newer.
09-16-2012, 05:44 PM
I've seen evo Sportster rocker boxes used on big twins too.
Mike
09-16-2012, 07:54 PM
Head breather bottom breather and the sportster ones fit too
09-16-2012, 09:10 PM
Good to know.........lookin to put lipstick on a hog. Thinkin Ester needs som more bling.
09-17-2012, 07:04 AM
pics when you're done my friend, pics!
09-17-2012, 11:41 AM
Quote:
Originally Posted by
aaamax
Some parts are on the way, and pics will be posted when the "transformation" is complete.
09-17-2012, 01:41 PM
Rocker Boxes are NOT the same
92 and earlier do not breath through heads, so if you put these boxes on a newer bike, the pressure will build up in the crank case/oil pan, and with nowhere else to go, the pressue will send the oil cap out into space.
Don't ask me how I found this out...
09-17-2012, 04:16 PM
Mines a bottom breather, so I dont think it matters what I put on the top. Dont they breath thruogh the head? Why would the spacer/valve cover make a difference?
09-17-2012, 07:03 PM
Since you have a bottom breather, it will not matter.
A top breather rocker box spacer needs an umbrella valve to work properly, but immaterial in your case.
