Electrical help
When I use my turn signals on my 95 flhr, my dash shorts out (mph, digital miles, display back light) not a big deal cause after turning everything comes back on after signal cancels. I hate electrical and Im no good at tracking it down, as always thanks for any suggestions.
Try reproducing the problem while its on the stand and then do a wiggle test on the wiring and connectors to find the trouble spot.
Yep, check the grounds, clean them and refasten them. Your speedo, etc. needs power and a ground to work, the only other common denominator is the W/GN wire that sends signals from the reed switch to the turn signals perhaps there could be a short in that.
John
John
Thanks guys all good advice I'm just kinda special needs in the electrical department. Yes the turn signals do work just cuts off dash when they are on. I wont have a chance to touch it till Wednesday, Ill post results.
It must be magic. Before I did I turned everything on and it all worked. Took it for a ride to warm things up, the heat out here does cause electrical issues. Nothing, it all worked. Not being a believer in the fixed it self theory, I took the dash off moved things around checked the ground all seemed well. Put it back together and it still worked. I'm riding to Tucson tomorrow night so, when things do go out I'm sure it will be on that trip.
The best way to find / solve a intermittent wiring problem is to go through your wiring system and clean / lube all connectors and wiggle test the wires for opens in the circuit. Pay special attension to the harness at the forks pivot point where the wires are bent each time you turn .
Body grounds are usually ok. if they are tight with no rust accumulation.
Check for good connections at ground busses.
