1989 FLHS fastener torque specifications
Old 04-05-2013, 10:59 AM
03dragonRK's Avatar
03dragonRK
03dragonRK is offline
Default 1989 FLHS fastener torque specifications
I am replacing the drive belt and I am without a manual. Can anyone provide me with the specs for the Compensator nut, clutch nut, swing arm nut, and the rear axle nut?
Old 04-05-2013, 11:16 AM
bluharley's Avatar
bluharley
bluharley is offline
On my 88 FLT, should be the same. Comp nut: 80-100 ft-lbs, Clutch hub nut: 50-60 ft-lbs, rear axle nut: 60-65 ft-lbs,not sure about the swing arm, tight is all I know. My book shows 45 ft-lbs for some bikes, and 85 ft-lbs for others. Why the huge diff puzzles me.
Old 04-05-2013, 01:57 PM
03dragonRK's Avatar
03dragonRK
Thanks - I will make sure it is at least 45#. Looks like the only change from my 03 is the rear axle (95 -105 for the 03)
hdfatbob12
01-03-2024 10:52 PM
harley_jeff
06-12-2016 12:22 AM
03dragonRK
04-05-2013 10:57 AM
03dragonRK
All Other Models
04-05-2013 08:41 AM
3itodd
09-26-2012 07:50 AM
Quick Reply: 1989 FLHS fastener torque specifications
