So I'm going with black nylon sheathed/braded oil lines instead of the stainless braided. Have a favor to ask. Can someone take a pic of the two lines to the filter? I know one comes from the oil tank and the other to the pump on the rear of the motor. Since I have to cut these myself, I just want to know exactly where they are run along the frame, away from the exhaust, etc. Really appreciate any and all help. Thanks!
Can I just ask why nylon over stainless? I'm looking at changing my lines too is all
I purchased the Drag Specialties Stainless Steel Braided kit. Wasn't thrilled with the quality at all - especially for the price. A lot of feedback I got (on here and in "real life") was I was better off going with the standard rubber tubing and clamps. Returned the lines and saw that J&P had braided nylon in black. And since my bike has a blacked out theme, I decided to go with that. The material had nothing to do with my decision. Well, except for the fact that the tubing will be easier to cut & trim. As opposed to stainless tubing if I had purchased a roll of that & clamps.
Ok, forget the pics. How about just confirming for me that the line from the pump exits the pump, drops down and goes forward to the oil filter from below the engine??
Thanks. But both lines run under the engine?? Not along the right side frame rail??
I think it depends on your bike. On my bike, the lines run along the right frame rail to the oil cooler. The filter is under the transmission. Run them however you want, as long as you secure them down so they don't move. If they move, bad things happen to oil lines.
Thanks. Yeah, I don't have a cooler. Filter is up front. I want to run the lines in their stock location. Obviously secure them properly and keep them away from the exhaust or any moving parts.
the center of the oil filter is the exit from the filter to the return fitting of the oil tank -- the fitting off to the side ( top / bottom ) of the filter housing is the input from the exit side of the oil pump ----
the oil travels to the filter into the side fitting and exits the center back to the tank --- johnjzjz
Thanks! I'm ok with which line terminates where and their functions. Just concerned about the physical location of the actual lines in relation to the engine/frame/exhaust.
