Scissor Jack
Old Mar 21, 2014 | 11:27 PM
ynots's Avatar
ynots
Originally Posted by miacycles
Glue some rubber or carpeting on top of it.
John
Exactly what I was thinking. I would fab up a wider base to increase stability
Old Mar 21, 2014 | 11:43 PM
Beemervet's Avatar
Beemervet
Not necessary.
Old Mar 22, 2014 | 12:39 AM
ynots's Avatar
ynots
famous last words
Old Mar 22, 2014 | 07:32 AM
Beemervet's Avatar
Beemervet
Originally Posted by ynots
famous last words
nope, just years of experience Twinkie.
Old Mar 23, 2014 | 09:23 AM
ynots's Avatar
ynots
Whatever floats your boat. I like something that has a base wider than the frame rails.
Old Mar 23, 2014 | 09:36 AM
grbrown's Avatar
grbrown
For using under both frame rails that is a jolly good idea. When I started riding Harleys, before the bike lift was invented, it was normal to lift the bike under the r/h rail and onto the jiffy!
Old Mar 8, 2015 | 02:01 PM
Uncle Larry's Avatar
Uncle Larry
Remember the old "Duo Lifts" ... They were great for working on the scooter ... Sure weren't portable though.
Old Mar 8, 2015 | 02:04 PM
Bigman405's Avatar
Bigman405
Originally Posted by Schex3x
I want to change fork and rear shock oil tonight.
I got a new Harbor Freight table yesterday and need a scissor jack.
So I went to the local salvage yard to look for a car jack I could maybe use.
I found one I think came from a '90s Chevy S 10, the guy at the yard gave it to me but could probably be had for 10 bucks or so.
A 14" piece of 2" channel fit good, so I welded it on.
The only other modifications I did was remove the handle so a socket could be used, and relocate and subsitute one pin with a bolt because the jack was designed to lift on a slight angle.
Threw some paint on it and it works just fine.
I figured other El-cheapo Evo owners like me might want to make use of one.
Thats an awesome idea. Going to build one or maybe even two of these. If I had two of theses the install of my shotgun shock would have been way easier. The motorcycle Jack I used didn't have much room for me to install my compressor which mounts in front of my shocks because I have ABS.
Old Mar 8, 2015 | 02:13 PM
mcain49's Avatar
mcain49
Check out Discount Ramps. They have a good selection of motorcycle scissor jacks that are reasonably priced. I just ordered the Black Widow jack that has a 9" base and lifts to about 15" inches. Very compact and when fully closed only stands 3.5" which makes it easy to fit under low bikes and stores easily without taking a lot of space. The jack gets good reviews and s rated to support 1100 lbs.
Old Mar 9, 2015 | 04:20 AM
Yankee Dog's Avatar
Yankee Dog
Just a thought: drill few holes in the base of the jack and a matching hole on the deck of your lift so after it is all positioned, you drop a bolt through it so it can't slide/kick out on you. Probably will never happen, but, you never know. At least install/glue some rubber to the bottom of the jack so it grips the table top a little better than metal on metal. I use the same jack. YD
