Oil flush?
Oil flush?
I saw something somewhere where this guy said the way to change oil on a big twin (he happened to have an FXRS very similar to mine) was to drain and refill the tank, then pull the filter and then put an oil pan under the filter mount while you run the engine for a minute or two. The idea was to allow the oil pump to flush out the rest of the used oil from the system.
Is this worth doing? Actually, I just did it and I wonder if its a waste of time or not.
Received 4,319 Likes
