Exhaust Leak
Exhaust Leak
So, I installed the V&H Pro Pipe. I removed the stock exhaust gaskets and installed the H-D SE gaskets only because I read that others had good luck with them. I should have had someone help me when I was lining up the pipes and flanges into the exhaust ports, but I thought everything was okay because I didn't have any problems getting the nuts threaded onto the studs and it looked like the pipes were seating into the exhaust ports just fine. I tightened everything to spec and in the right sequence according to the service manual, but I think the rear pipe is leaking around the top of the flange because I think I smell exhaust. Also, I used one of those multi-purpose charcoal lighters and the flame gets blown out when held next to the top of the flange. And, I'm getting some moderate decel popping. The front flange is not leaking.
So, I guess my question is what should I do? Do I have to remove the pipes and start over again (ugh!) or will the leak eventually stop? I've read some people stack two gaskets in each port, which I thought about doing, but didn't. Please advise. Thanks!
