Exhaust issues
Exhaust issues
so tonight I finished installing my new Cobra Pro Pipe HP 2-1. I stupidly misread the torque specs and tightened all four flange bolts to 15 ftlbs when I realized I screwed up I backed them off the re torqued them at the specified 120 inch lbs. shortly after starting it I got a loud pop from the front header my question is did I ruin the exhaust gaskets by over tightening or what should I do???
Every thing seemed intact I loosened all of the nuts. Nothing popped when I retorqued it, it was after I had started it and revved it up. Would an exhaust leak at the head sound like a loud pop? I'm going to remove the system in the morning and double check anyways. Thanks for the info more is always welcome.
eds06roadglide
11-03-2010 06:20 PM
