Installed new EV3 Andrews cam and 42mm Mikuni carb.Installed carb first ran great.Installed cam runs strong but popping air back threw carb @ idle could use some info!!
I'm sure I checked the marks 3 times . I sure the marks lined up perfect.I have good compression in both cyl.Could it be a bent valve or weak spring.i guess I pulling it back down to ck the marks,one more time.Any other way to tell for sure.
