Manifold Alignment
Old Oct 25, 2005 | 06:59 PM
Reffixer's Avatar
Reffixer
6th Gear
Default Manifold Alignment
Bike: 1975 XLH, Ironhead, Bored .030 over, Bendix carb. the rest is all stock (as far as I know)?
Problem: Cannot achieve smoothe idle by mixture adjustments, and engine surging up and down at coasting speeds. Poor starting etc.
Suspect Vaccume leaks. I removed the heads etc. to check for suspected gasket leaks. Found rear gasket discolored partly, and hope new gaskets will fix something. All the intake seals looked OK, but I don't trust them. Replaceing all gaskets.
QUESTION: How can I assure proper alignment and a good seal on the intake manifold, carb, and heads when reinstalling them.
Do I need some majic sealer compound.
Can I check the cleaned up heads for poor valves without dismantleing the rocker boxes.
Thanks to all for any advise.
Reffixer.
Old Oct 25, 2005 | 10:40 PM
pococj's Avatar
pococj
Default RE: Manifold Alignment
This applies to Ironhead Sporties and Shovelhead Big Twins:
If you ever remove the intake manifold of a Shovel motor it’s a good idea to check how it aligns with the spigots on the heads. If it doesn’t align well, you’ll probably end up with a leak sooner or later. The best method is to loosen the heads and adjust their position to match the manifold. Once the head bolts are loosened, you’ll notice you can actually rotate the heads a bit.
One method is to put your manifold in place between the spigots and then start tightening the head bolts. Look at the gaps between the head spigots and the manifold to see if it's aligned correctly. Adjust the heads as needed.
Another method is to install the manifold without the o-rings. Install the clamps and tighten them, and the loose heads will align themselves to the manifold. Now tighten the head bolts in the standard crisscross pattern to 15 or 20 ft. lbs. Remove the manifold and finish tightening the head bolts to the proper torque specs.
You can make a leak tester to check your work by fabbing some type of cover for the front of the manifold. A piece of metal with holes drilled to match the holes of your manifold, and another hole for some method to connect an air line, works fine. To test your manifold-to-head connections pump about 5 psi into your contraption. Yeah, you gotta make sure both your intake valves are closed! Use some leak detector or make some with soapy water. Slosh it on the head-to-manifold joints and watch for bubbles.
When you are installing those dang o-rings, roll ‘em up onto the head spigots, but make sure they don’t twist when you slide them into the gap. Then before you put the clamps on, take a wrap or two with some electrical tape around the o-ring. Use some good tape, not the el-cheapo crap from the bargain bin. I like either Scotch 33 or Scotch 88. 33 is thinner and more flexible.
Some folks don’t like the tape routine. It does goo things up as the tape gets warm. And that is one reason it helps seal things. The next time you pull the manifold off, it easily cleans up with some good ol’ gasoline.
You folks with later model Shovels don’t have to mess with the o-rings; you’ve got those nice wide sissy bands. But things’ll still last longer if’n you align the heads and intake manifold.
Old Nov 2, 2005 | 02:38 PM
tim@tmgdesigns's Avatar
tim@tmgdesigns
I had an old Honda that I had the same problem with. I found the leak by spraying some starting fluid on the boots. When the idle speed increased I knew I found the spot.
Goodluck,
Tim
207XL
Ironhead
15
Jul 1, 2023 08:00 AM
pococj
Shovelhead
11
Jun 27, 2018 02:08 PM
DDH
Engine Mechanical Topics
Apr 26, 2016 05:50 PM
aces&8s
EVO
24
Jan 9, 2014 07:03 PM
HDF Tech
Jul 3, 2005 01:11 AM
