Fuel Tank filter screen
I have a 2006 Street Glide with EFI. The manal calls for a replace at 25,000 miles. The problem I am having is identifying what is is and if I have one to change or does it apply to carborators models only. I have looked thru the manual and done a search on-line here on the subject. Can onyone help me on this one.
RE: Fuel Tank filter screen
The tank does not need to be drained.....
The fuel pump plate is removed, you seperate the filter canister from the regulator, install the new filter, reinstall the plate and replace the pump plate screws with new ones....
If the gasket is brittle or cracked, you replace it as well....
It is in the Service manual, along with the Tq specs on the plate screws...
128auto
09-01-2019 09:31 AM
