Zigz.....
Old Dec 5, 2005 | 01:17 AM
MegaHDman's Avatar
MegaHDman
Default Zigz.....
I got your email, but your adress kept bouncing back.
To answer some of your questions. Its a 98" kit. I am running Static CR a bit over 10.75:1, gives me a running CR of about 9.5:1 The Cycle-rama heads feature 2" intake valves and 1.570" exhaust valves. Ports were extensively welded up and reshaped. Valve stem to rocker tip geometry properly set up as requested. Set the squishband to .027 using a cometic mls headgasket. Don't have it dyno'd yet, but I am expecting around 125-130hp realistically. The extra 3 cubes and reduced friction and heat from the nikasil coated cylinders should get me there. Don't know what pipes I'll be using, got 3 sets set aside(a set of Bassanis and 2 RB pipes), and will see which matches up best with the engine combo.
converted1
Touring Parts
May 3, 2016 07:05 AM
NCDEUCE
Feb 24, 2008 05:38 PM
NOTORIOUS1
Jan 11, 2008 06:45 AM
XfasteddieX
Sep 27, 2006 03:56 AM
