Sponsored by: Jekill and Hyde
Need help with install of SE ignition module
Old 10-14-2007, 08:53 PM
gunrunner's Avatar
gunrunner
gunrunner is offline
Default Need help with install of SE ignition module
Trying to get a new screaming eagle ignition module to work on a 2005 road king carb bike. I have tried to follow the password learning procedere with no success anybody done this that has any tips???
Old 10-14-2007, 09:22 PM
mentor70's Avatar
mentor70
mentor70 is offline
Default RE: Need help with install of SE ignition module
I have done it sucessfully! but it takes time and you should put the bike on a battery charger while your doing the procedure, this will keep the battery voltage up, if it drops the marring will not complete.
what parts are you having problems with?
secondly, you will be happier with a daytona twin teck ignition!
Old 10-14-2007, 09:43 PM
gunrunner's Avatar
gunrunner
I dont get any light to come on the speedo except the engine check lamp. It says the sec.light should come on but it doesnt(bike has no added sec. system) I do as it says but check engine light stays lit well longer than the 10 minutes and doesnt turn off as it says it should.
Old 10-14-2007, 11:19 PM
mentor70's Avatar
mentor70
mentor70 is offline
I just re-read my service manuel and it realy didnt say what to do without security. the main reason why you have this feature is to help gaurd against theift.
what happens when you just try and fire it up?
marktruckee
EVO
23
08-17-2018 03:19 AM
6jhnnyrttn9
09-14-2016 01:22 AM
chad1200se
09-09-2008 08:58 PM
gunrunner
10-14-2007 08:55 PM
Scott Preston
05-01-2007 07:14 PM
Quick Reply: Need help with install of SE ignition module
