RE: 95", 82cc chambers, flat tops, .030 gaskets
QUOTING myself after the discussion: My stroke is 4.00". My intakevalves will close at 36 degrees after.I needsome help figuring outwhat compression ratio Iwillbe at?I'veused some calculators at some of the major builder websites and I come up with different answers.I want to make sure that I'm in the ball park of 10:1 compression.
Thanks
Just to help myself and to squelch myfriendsnagging meand anyone else thathas questions of their own; I CC'd my heads with a syringe and water. They are dead on 78 CC's. I checked them twice because I know how I am.
Thanks
go to bigboyzcycles.com
then go to their calculator section - there is a place to fill in your engine specs and the cam you are using - gives you the hot and cold compression and even the corrected compression based on the specific cam you have.
nice.
nice.
ORIGINAL: drdave
nice.
nice.
ORIGINAL: mentor70
You will be around 9.7 to 9.8 to one. my cam closes and 40 deg. after and I have 200 lbs of cranking cylinder presure.
you will need a 4 cc pop-up piston to make a mechanical 10 to 1.
This is how my motor is setup.
Big Boyz calculators are correct, go with those and skip the others.
I had 82cc chambers, S/E flattops, .030 head gasket, 0 DH.........and I was at 9.63-1 CR.
Now I have 78cc chambers, S/E flattops, .030 head gasket, 0 DH..........and I'm at 10.04-1 CR.
Steve
Steve
I'm using the HQ-0039-G cams. I asked my Head work guy to mill my heads to put me at 10:1 compression. They put my "CC" number on my sales reciept at 82 CC.
I know that my cams will work at this compression ratio, but I would rather be at 10:1 compression. I'm going to contact my Head work guy and see if this was written incorrectly, before I jump to conclusions. I'll get back with you guys later. Thanks for the input.
