CARB JETTING
Old Mar 3, 2013 | 05:48 PM
gsxrboy96's Avatar
gsxrboy96
Originally Posted by cjones55555
I drilled through a plug on the left side of the carb, not the plug I should have on the bottom. Not sure what to do next.
That's no good, depending on what you did, you might need a carb and a service manual. As others have said, you should look on nighrider for detailed instructions ,
Old Mar 3, 2013 | 05:51 PM
Imold's Avatar
Imold
Originally Posted by RANGER73
Unless your buying a used re-jet kit, the instructions are in the box. And no you can't do it without removing the carb.
I've done it just loosening the carb enough to pull it free of the intake and rotating it about 90 degrees. If you're gonna do the needle washers too, that's a different story.
Old Mar 3, 2013 | 06:36 PM
RANGER73's Avatar
RANGER73
He did say he was.
OP, you F'ed up big time. New carb in your future.
massparanoia
Oct 26, 2015 08:43 AM
CSS_FXD
Aug 17, 2014 01:56 AM
03 Softail
May 13, 2006 08:47 AM
HDF Tech
Carburetor Related
Mar 19, 2006 10:08 PM
radloser
Feb 4, 2005 09:40 PM
