IS THIS NORMAL?
May be a stupid question but here it goes.When you bike is at idol and you crack the throttle wide real fast it stumbles for a secondlike it takes a second for the rpm to jump.When I twist the throttle fast but more gradual it is fine.Just like if I am in first coming to a stop and I hit the throttle real fast it hesitates just for a second as if the rpms were a bit to low and lugged for a second.thx
If it were a carb it sounds like a accelerator pump thing.
Since it is EFI the thing that does the same thing, to most extent, is the accelerator enrichment table. It's a SERT thing. Real easy to \\;adjust if you have a SERT.
There are some other aftermarket tuners that can, I believe, fix this.
When you wing the troddle open there is a momentary lean condition, weather Carb or EFI, that has to be addressed. Engine goes, "GASP". not enough \\;fuel.
utexasrider
May 29, 2007 05:09 PM
