Lifter noise
RE: Lifter noise
Well lets see how long have you noticed the noise first off??
Has the bike been sitting for a while?
Were the mods recently performed??
Does the noise go away after riding it for a while ?
It is possible the the lifters have bleed down or that you have one bleeding down on you ?
RE: Lifter noise
 \\; Do you know if you have a high lift cam in it? It could be that there are clearance issues with the top covers. It could be a bad lifter or the pushrods not adjusted properly.
 \\; It could be a number of things! Also, does it make the noise only when the engine is hot or all the time?
