Sponsored by: Jekill and Hyde
Pistons?
Old 07-02-2008, 03:18 PM
rodmodder's Avatar
rodmodder
rodmodder is offline
Default Pistons?
I just bought a set of pistons out of a 103" screamin eagle fat boy.&nbsp\\; Is there any reasons they wouldn't fit in my 07 flht to make it a 103"?
Old 07-02-2008, 08:04 PM
vibr8ir's Avatar
vibr8ir
vibr8ir is offline
Default RE: Pistons?
The 96" motor can be punched to 103", SAME as a 88" to a 95".. same barrels too..Steve
Old 07-03-2008, 09:02 AM
Craig C.'s Avatar
Craig C.
Craig C. is offline
Just rebore your cylinders or buy a set of big bore jugs from harley and you will have your 103.
Old 07-03-2008, 02:58 PM
mtclassic's Avatar
mtclassic
mtclassic is offline
depends on what year the 103 pistons are.&nbsp\\; If they are from a year prior to 06 dyna or&nbsp\\;07 bagger they will not work as the cranks are different.&nbsp\\; If they are 103's from an 07 bagger disregard above statement.
Old 07-03-2008, 10:02 PM
6 gun's Avatar
6 gun
6 gun is offline
Received 1,743 Likes on 980 Posts
Erik
&nbsp\\; 2 reasons!&nbsp\\; &nbsp\\; 1 is juggs,&nbsp\\; 2 is heads,&nbsp\\;&nbsp\\;Your &nbsp\\;jugs can be rebored to the size of your pistons or you can buy&nbsp\\;SE jugs
part number 16546-99 black or 16549-99 silver. Your stock 07&nbsp\\;heads&nbsp\\; are for flat top pistons, so in order to use the 103 cvo pistons you eather need to use SE&nbsp\\;103 cvo heads parts numbers 16900-03a "front" and16977-03a "rear" at $600.00 ea,
or SE 103+ heads part number 17071-03b black&nbsp\\;$1,149.95 or 17072-03b silver $1,099.95&nbsp\\; I am hoping you all the luck in the world
Old 07-04-2008, 05:37 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
Yes they will work fine
pkachoochoo
06-28-2017 10:00 PM
0ldhippie
13
05-08-2015 06:18 PM
bigdog1949
03-16-2012 06:45 AM
rcpilot_971
09-21-2008 09:49 AM
giddiup
02-16-2007 02:23 PM
Quick Reply: Pistons?
