New Exhaust?
With just reasonable slip-ons you won't have to do anything. But you may well be happier in the long run to just get it over with. Check out what Jamie has at http://www.fuelmotousa.com/
If you change the exhaust plumbing in front of the mufflers in any way you will need to adjust your fueling whatever else you may do.
All I am looking for is sound. Will Vance & Hines slip ons be as loud? If I got the full exhaust system (just becaus i like the looks of the shotshots better) do i have to purchase a tuner or is there someone i can take it to to get tuned?
I will end up getting a SE intake very soon.
Thanks for the help
Thanks for the help
I agree, just put on my new slipons two weeks ago from Fuelmoto. I got the Rush mufflers with Fuelmotos designed bafflels, 1.75 reflected left and the 2.00 on the right. It simulates a 2 in 1 system. They have many hours testing the 07 and 08 with the oem headpipes.This setup really rocks! I was running AN bigsucker ac and a fuelpack with Screaming Eagle mufflers.I highly-highly recommend Fuelmoto!!!!
