VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
DX Exhaust upgrades
Old Mar 20, 2009 | 01:23 PM
chinookdriver's Avatar
chinookdriver
6th Gear
Default DX Exhaust upgrades
So I've been looking around online and have been asking my dealer about what I need to know when adding new slip ons and what not. It seems there are two different answers out there. I have a 09 Night Rod Spec. Im not really into tricking out the performance of the bike, just want the exhaust louder. Ive looked at the V&H widow slip ons and also the Thunder header exhaust. Either way, online tells me that I need a new tune for the engine if I do anything. The Dealership says I only need the tune if I upgrade to a High flow Air Filter as well. Whats the Deal? I know these bikes are a bit different than most Harley's because of their water cooled nature and design. Any help is appreciated.
Old Mar 20, 2009 | 06:14 PM
sfarson's Avatar
sfarson
The dealer is correct. Typically, the FI only needs to be tweaked if modifying the air intake and/or header pipes. If you just swap mufflers most FI systems can accomodate. Like you, I'm not into heavy mods. I just swapped the stock exhaust cans for the Supertrapp Fatshots. Read somewhere they are the biggest selling exhaust upgrade for the DX. Can understand why... a richer/deeper tone, great performace with those tunable discs (8-10 depending on altitude), less weight, sweet appearance. Now after two years with them, would do the same thing without hesitation... just place them, no other mods.
Can hear them in the ride vid here: http://www.farson.com/video/dxjuniper.wmv (esp at around 2:00)
Appearance...
Old Mar 21, 2009 | 06:28 AM
05Fatty's Avatar
05Fatty
The only slip-ons I would suggest doing without a tuner would be SuperTrapp like in the pic above. If you run 8-10 discs it doesn't need tuning. They are not extremely loud like the thunderheader but they do have a nice rumble that is definately louder than stock. The beauty of the tuner is that it really wakes these bikes up and they feel much stronger.
Old Mar 21, 2009 | 05:38 PM
chinookdriver
6th Gear
Thanks guys for the help. Those look great. I like the touch of chrome at the end. It really sets everything off right. I read that they come with 12 discs which, if I read correctly, would be the loudest and least amount of backpressure so it seems 8-10 discs would be pretty close to the max. Oh one more question, if I decide to put on a intake upgrade on, would the dealer Screaming Eagle tune work or should I go with an aftermarket programmer? Would this also allow me to add in the last 2 discs to the exhaust and still run ok? thanks again
Old Mar 21, 2009 | 07:27 PM
Herr Monk's Avatar
Herr Monk
Getting the bike tuned is not really "tricking it out", it's pretty standard for both the Air-Cooled, and V-Rods to have a high-flow A/C put on, and have it tuned. The factory tune is relatively weak.
My guess, is that you'll end up doing it sooner or later, and you'll save money by doing it all at once, and getting the exhaust (slip-on or full-system) you really want off the bat, getting a high-flow A/C and a tune.
Old Mar 22, 2009 | 02:41 AM
chinookdriver
6th Gear
Thanks for the info. So how do these bikes do with non-baffled exhaust or straight pipe? I was told they need to be somewhat baffled to keep the backpressure, which the engine needs in order to run better.
Old Mar 22, 2009 | 05:00 AM
Herr Monk's Avatar
Herr Monk
If you have a well designed pipe, and a good tune, you don't need more back-pressure on any engine.
Baffles are good for sound control.
Maximum performance is achieved at maximum exhaust velocity at a given engine speed. No pipe is perfect for all engine speeds. 2>1s are the best, and great the widest powerband.
Baffles slow exhaust velocity.
Straight-pipes are pretty low-tech, and are not ideal for anything. They will produce the closest thing you'll get to a traditional Harley sound. You will loose power vs. stock 2>1>2
Old Mar 22, 2009 | 02:28 PM
chinookdriver
6th Gear
ok. think I have a good idea on where to start now. Thanks fo rthe help. The thunderheaders sure are loud but im not sure its for me (also considering CA's stupid SMOG laws coming out soon). I like the look of the SuperTrapp slipons. I think I'll do that and the high flow air filter and get my dealer to put on the SE tune and see how it goes. I can always add on a fueler after that if things aren't working out. Now to go check out the Forums and figure out the whole "topless" thing.
Old Mar 22, 2009 | 02:31 PM
Herr Monk's Avatar
Herr Monk
There's no "SE Tune"... HD hasn't made "flashes" for the VRSC line in awhile... if some tech thinks he's gonna reflash your ECM, I'd be concerned...
Old Mar 22, 2009 | 06:05 PM
wood butcher's Avatar
wood butcher
Appearance...
OUTSTANDING VIDEO! Great music. Nice job.
