head gasket help please
11-29-2008, 11:30 AM
whats the stock head gasket size on a 2005 twin cam
11-29-2008, 06:27 PM
The Bore is 3.75" on a an 88/96" motor...
11-29-2008, 09:07 PM
thanks but meant .055 or .040?
11-29-2008, 10:45 PM
Then you would word it as ".... what is the thickness of the stock head gasket?"
The reply would be .055 prior to torque, and about .038-.045 post torque....
Those gaskets are not high on anyones listing for a quality gasket irt measuring squish...
Get the Cometic MLS gasket.... Properly torqued it will compress to .028-.035....
11-29-2008, 11:54 PM
thank you what would the .030 or .040 torque down to if I whent with them on a 95 build and on stock heads with flat tops would it still be wise to mill them abit
thanks
11-30-2008, 07:38 AM
Use the SE or Cometic .030 MLS gasket if you are concerned about CCP and squish....
The HD Graphite impregnated gaskets are inconsistent in their final dimensions...
11-30-2008, 11:50 AM
dyna50
Engine Mechanical Topics
08-05-2023 02:51 PM
cvaria
08-23-2018 02:00 PM
roadgliderick
09-24-2012 12:39 AM
speakerfritz
10-05-2011 06:25 PM
Fl Jimbo 05
08-11-2011 10:11 PM
area ,
compress ,
crush ,
evo ,
gasket ,
harley ,
head ,
intake ,
seal ,
shovelhead ,
shovelhead040 ,
size ,
squishing ,
stock ,
thickness ,
torque ,
torquing
