Piston types
Old Dec 23, 2008 | 12:44 AM
Rebel78's Avatar
Rebel78
Question Piston types
May some1 plz explain to me the difference between Flat top pistons & reverse pistons? Which one is better?
Old Dec 23, 2008 | 01:25 AM
hollywood1959's Avatar
hollywood1959
When we built blocks back in the 70's,a flat top was almost a stock piston. It had more compresion than the standard one. A high dome would crush your mix allot harder. The motor had to be built for it. A reverse was used for turbo mods. I may be wrong, I hope the boys and girls chime in on this to set this right.
HOLLYWOOD
Old Dec 23, 2008 | 07:04 AM
NTrat's Avatar
NTrat
flat tops are just that, flat on the top. Reverse dome(dished)pistons you arent going to use. Best to either use flat tome pistons or domed for your build.
Old Dec 23, 2008 | 01:41 PM
new_mentor70's Avatar
new_mentor70
basicly, in a nut shell flat tops are best, but if you need to change compresion with a certian combustion chamber size AND keep your quench correct you may need a dished piston, nothing wrong here as long as the quench is still around .030. and the cylinder presure is what your cams require.
a pop up is used to raise comprsion, but the heads will require some CCing to make the compresion right for your cams, and equal between the cylinders.
a builder will use any combonation to get the desired quench and compresion for the desired results.
Old Dec 23, 2008 | 03:45 PM
NTrat's Avatar
NTrat
Technically I think domes are best for combustion turbulence/af mixture etc, but flat tops keep things simple and are very easy to work with.
Old Dec 23, 2008 | 08:25 PM
new_mentor70
deffinantly a highly debatable topic, lots of builders belive that the domes obstruct the flame travel and interfere with combustion.
to me, the combution chamber should be the only factor in controling flame travel and use a flat top piston, but I currently run a pop up, and it has had no ill effects on my bike.
Phil M runs an 11.0 to 1 120 with a reverse dome or dish piston and has incredible results.
the quench I feel is the most important issue above all.
Old Dec 24, 2008 | 08:38 AM
NTrat's Avatar
NTrat
I will agree its very debatable with great arguments on either side of this coin, kind of why I said what I did.
Old Dec 24, 2008 | 05:35 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The "dome" on a T/C, or Evo engine, is basically a flat-top type piston, by design, as opposed to large, raised dome pistons of yesteryear, that inhibit flame travel, and block air flow characteristics as well.
You need to use what is needed, for the intended build.
Scott
Old Dec 24, 2008 | 09:25 PM
Dalton's Avatar
Dalton
I agree with Scott, you should run what you need for the build to get your desired results. I too am running slightly dished pistons in my 120" at 10.5:1.
saz
Engine Mechanical Topics
Feb 13, 2015 01:08 PM
txphatboy
20
Apr 16, 2013 07:47 AM
lieutenant G
Jul 9, 2012 09:48 AM
Mi3ninos
11
Apr 28, 2010 08:52 AM
UltraKla$$ic
Sep 24, 2009 11:08 AM
