cv jetting recommendations
04-16-2006, 09:15 PM
I need to jet my carb. I have a twin cam with a screaming eagle air cleaner with k&n and some s&s mufflers. On the recommendations in the diy column do you not change out the main jet? Thanks.
04-18-2006, 10:44 AM
RE: cv jetting recommendations
I would just bump up the low speed and adj the air screw for now.
Ride it and see what other changes are needed.
04-18-2006, 12:47 PM
46 low speed jet, 190 high speed jet, raise needle 50 thousands( 2 small washers). Adjust mixture screw out 1 1/2 to 2 1/2 turns. Worked good for me.
04-18-2006, 07:59 PM
I know I'm running lean. It likes to hickup through the carb quite a bit on the low end of the throttle.
massparanoia
10-26-2015 08:43 AM
wisconsinhd1995
Carburetor Related
03-02-2014 01:11 PM
gulfvet
Exhaust System Topics
03-03-2013 06:36 PM
supr2nr
Ironhead
04-14-2008 01:26 PM
HDF Tech
Carburetor Related
03-19-2006 10:08 PM
